clear errdisable - is not working
kozorezdi
Hello everyone,
from cisco site:
You can re-enable a port by using the shutdown and  no  shutdown interface configuration commands, or you can clear error disable  for VLANs by using the clear errdisable  interface command.
This example shows how to re-enable all VLANs that were  error-disabled on port 2.
Switch# clear errdisable interface GigabitEthernet 0/2 vlan
Practice:
I have got on a L2-switch (C2960 Software (C2960-LANBASEK9-M), Version 12.2(44)SE6) a port in err-disable state.
interface GigabitEthernet0/15
switchport access vlan 103
switchport mode access
switchport port-security
switchport port-security mac-address 0000.0000.0001
speed 100
Switch_Colo_Cisco1#sh run int gi 0/15int gigabitEthernet 0/15
GigabitEthernet0/15 is down, line protocol is down (err-disabled)
Switch_Colo_Cisco1#clear errdisable interface gigabitEthernet 0/15 vlan 103
Switch_Colo_Cisco1#sh  port-security
Secure Port  MaxSecureAddr  CurrentAddr  SecurityViolation  Security Action
                (Count)       (Count)          (Count)
     Gi0/15              1            1                  1         Shutdown
Total Addresses in System (excluding one mac per port)     : 0
Max Addresses limit in System (excluding one mac per port) : 8192
It was cleared only by shutdown/no shutdown on the interface.
Why the command 'clear errdisable int ... ' doesn't work properly?
Have a nice day,
Dimitry
You can configure either to shut down the entire port in the case of errdisable detection (which is the default) or int the cases of bpduguard and port-security violations you have the possibility just to shut down the offending Vlan instead of the entire port (since 12.2(37)SE IOS version with Cat2960). If you decide to configure just to shut down the Vlan (e.g. via the global configuration command "errdisable detect cause port-security shutdown vlan") then you can use the command in question (ie. "clear errdisable interface vlan) to clear the errdisable status (instead of shut/no shut of the interface).
Best regards,
Antonin
6 Replies 6
Ven Taylor
Level 4
Level 4
To clear the errdisable, perform a shut, then no shut on the interface.
Ven
Ven Taylor
hi,
yes it is clear.  not clear why we need the command "clear errdisable"...
Dimitry
gfcisco31
HI Mate..
The usage guidelines is as follows:
"Use the clear errdisable interface privileged EXEC command on the switch stack or on a standalone switch to re-enable a VLAN that was error disabled [clear errdisable interface (int-id) vlan (vlan-list)]"
So, i assume that by default will only recover SVI interfaces.
hope this helps
regards
Good morning,
Intersting... BUT  SVI it is a L3 interface...
errdisable reason:
bpduguard
channel-misconfig
dhcp-rate-limit
dtp-flap
gbic-invalid
inline-power
link-flap
mac-limit
loopback
pagp-flap
port-mode-failure
psecure-violation
security-violation
sfp-config-mismatch
small-frame
storm-control
udld
vmps
It is not for L3 interface at all.  btw on int vlan * we can't command 'switchport port-security'
Thanks for try!  My question is still without an answer ;D
Dimitry
Best regards,
Antonin
Hello Antonin,
Thank you very much for the explanation.
Have a nice day,
Dimitry
