04-18-2008 01:58 AM - edited 03-05-2019 10:27 PM
i want to see the latest nat translations, if i clear the logs using >clear ip nat translations
will it cause any disconnection to other computer?
04-18-2008 02:02 AM
If you clear all translations with
"clear ip nat translations *" then all exisiting connections with nat translations will be torn down. You are not clearing the logs you are clearing the actual translations.
You can be more granular and specify a particular nat translation.
Jon
04-18-2008 02:41 AM
how can i delete translations of specific computer?
04-18-2008 02:45 AM
Do a "sh ip nat translations"
and then
clear ip nat translation ? and you will see the options to specify a particular entry.
Jon
