clear not logged line vty 3560
hi!
how can I kill vty session on 3560G if user not logined?
sw#who
    Line       User       Host(s)              Idle       Location
   1 vty 0                idle                 11:23:17 host-xxx.net
*  3 vty 2     user    idle                 00:00:00 relay.xxx.net.ru
sw#clear line vty 0
[confirm]
[OK]
sw#who
   1 vty 0                idle                 11:23:27 host-xxx.net
1 ACCEPTED SOLUTION
You can try to clear stull TCP sessions within your switch.
You can first try to clear it with "clear tcp line #".
If did not help then check for those with show tcp brief
Those which are not established - are subject to be cleared.
You can clear those with
clear tcp tcb TCB_NUM (TCB_NUM from command show tcp brief).
Hope this helps,
Nik
hi maxim,
nice command you got there. i didn't even know the "who" command exist. i often used the show users command.
try using clear line 0 (without the "vty") instead.
hi john!
command without "vty" dont take effect as with "vty", session still exist.
VIP Super Bronze
Try this:
cle line vty 2
than try
sh line
should show clear now
hi, thanks for reply
sw#who
   1 vty 0                idle                    2d04h host-xxx.net
*  2 vty 1     user    idle                 00:00:00 relay.xxx.net.ru
   Interface      User        Mode                     Idle     Peer Address
sw#clear line vty 2
[confirm]
[OK]
sw#show line
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
     0 CTY              -    -      -    -    -      0       0     0/0       -
*    1 VTY              -    -      -    -   95  85440       0     0/0       -
*    2 VTY              -    -      -    -   95  77852       0     0/0       -
     3 VTY              -    -      -    -   95  78100       0     0/0       -
     4 VTY              -    -      -    -   95  76368       0     0/0       -
     5 VTY              -    -      -    -   95  18953       0     0/0       -
dont help
    Just try this
    sw#clear line 1
HTH,
Toshi
hi!
no result with "clear line 1".
may be IOS bug?
*    1 28    WS-C3560G-24TS     12.2(46)SE            C3560-ADVIPSERVICESK9-M
   What did you mean "no result"?
   Let me see the output of "show line"
Toshi
i mean that command "clear line 1" don't help (sorry for my english).
output "show line" i've posted above
sw#show line
hi maxim,
can you schedule a downtime and perform a reload on your switch?
hi jonh!
unfortunately i cant do it for now, this problem not so critical and this switch aggregate too many L2 sw. I shedule it for future.
thanks for help
Hope this helps,
Nik
Re: clear not logged line vty 3560
Hi Nikolay,
"clear tcp line 0" - without result
but
"clear tcp line 1" - this command kill my own session and
great, thanks!
1305
