clear show log output
hi,
how can i clear the log of the show log command ?
1 ACCEPTED SOLUTION
Re: clear show log output
I believe you are looking for the "clear log" command.
Mark
Mark
Hi mark.
Thanks, this is what i was logging for.
hi,
this erased the logs in the telnet session, but using the network assistant, the system messages and event notification are still there !
You might need to purge the logs in CNA, or restart CNA for the logs to disappear.
Mark
199
