Clearing arp-cache
Patrick McHenry
Level 3
Level 3
is there a way to clear one arp-cache entry in the 6509s. I have a mac that has two IPs associated with it. I could clear the arp-cache of the whole vlan? Would this disrupt any users on this vlan? Also, any explanation of why this would happen? The user was recently moved from vlan 2 to 29. Thanks
Internet  170.117.57.210          1   0011.2567.d84d  ARPA   Vlan2
Internet  10.10.28.119           58   0011.2567.d84d  ARPA   Vlan29
I would have to wait three more hours for it to clear.
5 Replies 5
lgijssel
Level 9
Level 9
You could try it like this:
The following example shows how to refresh dynamically learned ARP cache entries for the host at 192.0.2.140:
Router# clear arp-cache 192.0.2.140
Link:
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_arp.html#wp1011868
regards,
Leo
Layer3Switch#clear arp-cache 10.10.XX.XXX?
% Unrecognized command
Doesn't recognize
version: 12.2(18)SXE2
Yeah, there is still a lot of difference between the router images and those for switches.
That's why I said "you can try".
This was a command introduced in 12.0 so if possible, it would have been in there.
Nevermind. Only two hours to go before the problem resolves itself!
regards,
Leo
Thanks Leo. It was actually a dns issue. My Sys admin schooled me on it.
What i know abt Dns is, it resoves ip to hostname vice versa;
  so how it is affected in ur case.
