Webcast-Catalyst9k
Clients not receiving addresses from DHCP
I have a Cisco 2811 router and have configured it to be a DHCP server at a remote site.  It seems like it should be pretty straight forward to configure DHCP.  Apparently I'm missing something because I can't get clients to receive an address.  Below are the applicable parts of the config.  I also have tried associating the DHCP pool with the Claims vrf and that did not work either.
ip dhcp excluded-address 10.10.30.0 10.10.30.99
ip dhcp excluded-address 10.10.30.201 10.10.30.255
ip dhcp pool Claims_Office
   network 10.10.30.0 255.255.255.0
   domain-name fmi.com
   default-router 10.10.30.253
   dns-server 10.10.10.191
   lease 7
interface FastEthernet0/0
description Claims Office
vrf forwarding Claims
ip address 10.10.30.253 255.255.255.0
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0/0.1205
encapsulation dot1Q 1205
ip address 192.168.103.2 255.255.255.252
Everyone's tags (2)
Green
Nathan,
I think the issue is with your exclusions
This will exclude the full subnet
Can you try changing it to
no ip dhcp excluded-address 10.10.30.0 10.10.30.99
ip dhcp excluded-address 10.10.30.1 10.10.30.99
Then retry a dhcp test
See what the output from show ip dhcp pool looks like before and after the change
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Unfortunately that didn't
Unfortunately that didn't work.  Here is the output before:
Pool Claims_Office :
 Utilization mark (high/low)    : 100 / 0
 Subnet size (first/next)       : 0 / 0
 Total addresses                : 254
 Leased addresses               : 0
 Pending event                  : none
 1 subnet is currently in the pool :
 Current index        IP address range                    Leased addresses
 10.10.30.1           10.10.30.1       - 10.10.30.254      0
And after:
What I want is for it to assign addresses from 10.10.30.100-199
130
