clns routing
could someone explain the below command to me... thanks:
<br />
<br />mpls ldp neighbor 192.x.x.1 password 7
<br />mpls label protocol ldp
<br />no issu config-sync policy xxx xxx
<br />issu config-sync policy xxx xex
<br />
Re: clns routing
This command configures a passowrd with the LDP neighbor. The number 7 indicates that the passord that will follow will be encrypted with type 7.
The global mpls label protocol ldp command sets the default label distribution protocol for all interfaces to be LDP.
When two different versions of Cisco IOS images are involved, there is a possibility that the command sets supported by two images might differ. If any of those mismatched commands are executed on the active supervisor engine, the standby supervisor engine might not recognize those commands. This causes a Config Mismatch Condition
The no form of the command removes the defined policy
Narayan
Re: clns routing
Wonderful!! thanks for the quick response Narayan
132
