05-21-2014 09:48 AM - edited 03-07-2019 07:29 PM
Does anyone know what is causing this? I see this on:
- Cisco Network Assistant v5.8.5.1
- Cisco Network Assistant v5.8.9.1
When I click OK, the VLAN dialog is blank, but if I click Refresh it updates and shows them. I'm afraid to actually edit anything via CNA, as I don't know if CNA is malfunctioning due to the initial error, and may destroy the running config.
05-21-2014 10:11 AM
I was not aware that CNA did application logging, but I see this in my user profile:
Application_Log_Wed_May_21_11_17_19_CDT_2014-1400689039821
This appears to be the relevant errors. There are no times on these log entries so I don't know if this is exactly it:
com.cisco.cpnm.frmwrk.gen.ssh.SSHEngine@4845fb 10.17.0.5 End Calling sendCommand....
com.cisco.cpnm.frmwrk.gen.ssh.SSHEngine@4845fb 10.17.0.5 Calling readDevice....
com.cisco.cpnm.frmwrk.gen.ssh.SSHEngine@4845fb 10.17.0.5 End Calling readDevice....
com.cisco.cpnm.frmwrk.gen.ssh.SSHEngine@4845fb 10.17.0.5 Calling sendCommand....config paging disable
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.RangeCheck(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
at com.cisco.cpnm.features.dsbu.defn.vlan.VlanMembershipTask.updateMirrorFromDevice(VlanMembershipTask.java:166)
at com.cisco.cpnm.frmwrk.gen.wd.WDContainer.updateMirrorFromDevice(WDContainer.java:590)
at com.cisco.cpnm.frmwrk.gen.wd.WDTabbedPane.updateMirrorFromDevice(WDTabbedPane.java:953)
at com.cisco.cpnm.frmwrk.gen.wd.WDContainer.updateMirrorFromDevice(WDContainer.java:597)
at com.cisco.cpnm.frmwrk.gen.wd.WDWidget$2.run(WDWidget.java:1193)
at java.lang.Thread.run(Unknown Source)
