cna
why CNA DOESN' Work with the 4500 & 6500 series?& what is the benifiTS of the CNA?DOES The 4500 & 6500 work with ciscoview only?
10xs
Silver
Re: cna
Hi ,
Cisco Network Assistant is a PC-based network management application optimized for wired and wireless LANs with up to 250 users. By using Cisco Smartports technology, Cisco? Network Assistant simplifies configuration, deployment and ongoing management and maintenance of Cisco networks. Cisco Network Assistant provides a centralized network view through a user-friendly GUI. The program allows network administrators to easily apply common services, generate inventory reports, synchronize passwords, and power up other features across Cisco switches, routers, and access points
At the present time the 4507 switch is not supported with CNA. Mainly the 2900/3500/3700
line switches are supported, with additional switches being added in future releases.
Please take a look at the CNA release notes, as it defines which switches are presently
supported:
http://www.cisco.com/en/US/products/ps5931/prod_release_note09186a00802b92f5
.html#wp699844
Hope it helps you.
satish
Re: cna
sATISH;10XS FOR UR QUIK REPLY
187
