Collapsed Backbone & Cat Express 500
I have a collapsed backbone design with a single C3750G as a core switch and 6 Cat Express 500 switches as access switches.
Q1. Is it possible to cascade the 6 CE 500 access switches using their uplink ports ?
The first and the sixth access switch will have their uplinks to the core.
Q2. If I do a 802.1q trunk on all the cascade links, what are the spanning tree implications ? Which ones will block ? How do I get around this problem ?
Any advice is much appreciated.
Paul
1 REPLY
Silver
Re: Collapsed Backbone & Cat Express 500
A collapsed backbone has high-bandwidth uplinks from all segments and subnetworks to a single device, such as a Gigabit switch, that serves as a single point for monitoring and controlling the network.
http://www.cisco.com/en/US/products/hw/switches/ps5213/products_configuration_guide_chapter09186a0080214a43
122
