02-11-2012 08:39 AM - edited 03-07-2019 04:52 AM
Hi Netpro
if ur servers are directly connected to the Collapsed core/aggregation VSS, is it hard to insert IPS and run it in inline mode or add ACE Appliance?
unfortunately we don't have server farm switch
Please can y clarify
thanks
02-11-2012 10:22 AM
Hi Ibrahim,
you can still do that.
If you had 1 IPS (or ACE) only it is not a big issue; if you add a pair of them you need to make sure that they are in active/standby mode.
what issue are you exactly encountering?
Riccardo
02-12-2012 10:42 AM
I heard if u dont have server farm switch it is not possible to provision IPS or FW ,is that true
02-12-2012 07:39 PM
You can get creative and setup some transient VLANs to make it work. I do it all the time.
Interfaces on the IPS would belong to different VLANs connecting same switch, etc.
02-12-2012 11:58 PM
exactly, usually you have the IPS bridge 2 vlans to get it in the traffic path
02-14-2012 08:31 AM
Guys
can some one post a similar setup,where servers are directly connected to a collapsed CORE, while the IPS needs to be added inline mode
