Collisions detected in a Catalyst 4500
I have some problems with a WS-X4515 and a Broadcom NetXtreme Gigabit 5703. If I do a sh interface it will be appear collisions in that interface.
Re: Collisions detected in a Catalyst 4500
Check for speed/duplex mismatch.
There aren't duplex-mismatch and the speed is ok.
1000 Mbps Full-duplex in both sides
Here's a good place to start.
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_tech_note09186a008009446d.shtml
I am assuming this is an ethernet connection.
Generally collisons are the result of speed/duplex mismatches, a bad nic or cable or oversubscription. If you have a open port on your switch, try using that and check for collisions.
Thank you for the advice but I don't use a shared medium. The server is connected to the switch directly.
The connection is a Gigabitethernet.
In that case the collisions would be caused by a bad nic or cable. Have you tried replacing the cable or nic? You could also try moving the connection to a \different port on your switch to eliminate the port as the problem.
I have tried this but the problem persist. The problem only exists with the Broadcom NIC because I have others NICS and they don't have any problems
139
