01-14-2012 07:53 AM - edited 03-07-2019 04:21 AM
I'm trying to setup several macro's but in all Cisco manual's they tell me to use command "macro name ..." to create my macro. But when I want to use the command, my CLI only allows the follwing commands to me:
switch(config)#macro ?
auto Macro autoexecution settingsglobal Enter global macro configuration
So what have I to do to get this command "macro name ..." working?
The IOS I use is for example:c2960-lanbasek9-mz.122-50.SE1.bin
c3560-ipservicesk9-mz.122-55.SE1.bin
Kind regards
Kai
Solved! Go to Solution.
01-14-2012 02:55 PM
Since 12.2(50)SE, Cisco has been "threatening" to deprecate the "macro name" (which is part of the switchport macro feature) in favour of the AUTO smartport macro. The command "macro name
My fleet of switches are running 12.2(55)SE, 12.2(58)SE and 15.0(1)SE2 and I am still using the switchport macro on a daily basis.
01-14-2012 08:21 AM
Hi @ all,
I'm a fool....
The postet Command also permits "macro name myMacro" it is only not shown.
Kind regards
01-14-2012 02:55 PM
