02-10-2009 08:31 AM - edited 03-06-2019 03:57 AM
Customer is trying to use the command "ip load-sharing" in a 7609 with the version 12.2(18)SXF8 and it is not working. The same command in a 3640 with the version 12.2(27) is working.
Does someone knows if there is any restrictions from the hardware or IOS for this command on the 7609?
02-10-2009 09:01 AM
As far as I know, you can not do "per packet" load balancing (not supported) but you can do "per destination"
02-10-2009 09:30 AM
Could you tell me where I can find the information that the "per packet" load balancing is not supported.
02-10-2009 09:44 AM
Check Known Issues section.
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_tech_note09186a0080094806.shtml#knowniss
