command to clear cell delineation on ATM int
Hi all,
sh controllers atm0/0/0
Interface ATM0/0/0 is up
Hardware is ATM AIM T1 connected to AIM slot 1
hwidb=0x4827B4A8, sardb=0x473B27FC
slot 0, unit 0, subunit 0
MXT5100 versions: Framework 0x3383, Utils 0x3383,
AAL5 0x3383, AAL2 0x3383, AAL1 0x3383,
IMA 0x3383, CS 0x3383, Frame 0x3383.
Current (mxt5100_t)sardb:
Ind_Q(0xF72CD00), Ind_Q_idx(116), Ind_Q_size(30000)
Cmd_Q(0xF727EA0), Cmd_Q_idx(348), Cmd_Q_size(20000)
Inpool(0xF6F1080), Inpool_size(4096)
Outpool(0xF6F20C0), Outpool_size(4096)
Localpool(0xF700000), Localpool_size(256)
StorBlk(0xF57D000), host_blk(0xF4E9E00), em_blk(0xF4E9EC0)
tx_buf_desc(0xF720E20), tx_free_desc_idx (1022)
MXT5100 sub_channel_mode is disabled
MXT5100 number of buffers in Inpool: 1024, Outpool 0
FPGA revision 0x20700F1
MXT5100 Port Info:
Port Number (0), Port ID (0xE05)
Interface Number (4), Interface ID (0x12E1)
Port Type CELL, Port Open Status SUCCESS
VCs configured (1)
Port counters: tx_cells 338903902, rx_cells 360517350,
rx_hec_errors 74184, rx_cell_validation_errors 58050
Cell delineation PRESENT
Times cell delineation has been lost 1050
MXT5100 Channel Info:
Channel Info (0):
Chan_ID (0xEA5), Open Status SUCCESS, VC(1)VPI/VCI(1/777),
Tx Ring packets(used/max 2/40), Tx SBD(used/max 2/40)
Tx PDU(11381), Tx PDU discard(0)
Tx SDU size err(0), Tx cell CLP0(110476), Tx cell CLP1(0)
Rx PDU(11328), Rx PDU discard(0), Rx SDU size err(0)
Rx CRC err(0), Rx cell CLP0(154683), Rx cell CLP1(3628)
i want to clear cell delineation and
i used clear counter command that did not work is there any command which i can use to clear above errors?
many thanks
mahesh
1 REPLY
Re: command to clear cell delineation on ATM int
Mahesh,
Try to clear the controller for the ATM interface.
clear controller atm0/0/0
HTH,
Mark
639
