command to get status of CRC errors
roger.malik
i Have 6509 switch with 4module of 48 port each and i need to get status of CRC erros for each interface. does we have any command to get desire result. thanks
2 Accepted Solutions
Hi Roger,
If you want to know the only CRC errors of all up interfaces use this command...
sh interfaces | in up|CRC
HTH....Please rate all helpful posts
*aijaz*
glen.grant
If its IOS then its "show interface counters errors " . If catos then its "show port counters" .
7 Replies 7
Istvan_Rabai
Level 7
Level 7
Hi Roger,
If you want to know it on a per interface basis, then you need to enter the "show interface fastethernet x/y" command.
The output of this command will show you the errors classified by type, including the CRC errors.
Cheers:
Istvan
Hi Roger,
*aijaz*
thanks dud resolved my issue
No Actually i want to know it for all interface via single command like we have range command. any suggestion
I'm glad that it solved ur issue....and thanks for using the rating system..
You can use show port module/port-number to find out exactly of what you need.
there are few options you can use, for example
1 show port 8/42
...will give all information for the port 42 on module
2 You can also use show port 8
this will give required information for all the ports on mudule 8
3 You can also use show port
and this will give required information for all the port on the entire Chassis..
Shaheen
glen.grant
