Commands To Show Current MTU Value on Cisco 2821
Hello all,
I was wanting to know the command(s) needed to show the current MTU value in a 2821 router.
Thanks in advance
Peter Paluch
Willie,
There is no single MTU setting for a 2821 router. Each IP-enabled interface can have its own independent MTU. Therefore, you should check each interface separately. The commands:
show interfaces X
show ip interface X
Look for MTU in the output. Replace X with the name and number of the interface you are interested in.
Best regards,
Peter
Peter Paluch
Willie,
show interfaces X
show ip interface X
Best regards,
Peter
You are correct Paul, thanks a bunch
