Compatibility between ASR9K and SFP-H10GB-ACU10M
Hi Everyone,
I have in my environment two ASR9K with module A9K-16T/8-B and I am trying to connect using the Active Twinax cable 10M (SFP-H10GB-ACU10M), however when I connected the cable, shows the following error:
State:
    Administrative state: enabled
    Operational state: Down (Reason: Security failure (not a valid part))
    LED state: Red On
Phy:
    Media type: Not known
    Optics:
        Vendor: CISCO-TYCO
        Part number: 2163675-2
        Serial number: TED1618U0H0
I checked the compatibility list and apparently okay, as shown in the link below:
http://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/data_sheet_c78-624747.html
Please, the community can help me?
Best Regards,
Vitor Nakano
Everyone's tags (1)
1 REPLY
Bronze
Three years later...
You have probably solved but maybe it will help others.
Have you tried enabling service unsupported-tranceiver under global config? It a hidden command
You can also use transceiver permit pid all under the interface.
523
