Webcast-Catalyst9k
Compatibility Issue between catalyst 2950 and 2924's
I am trying to connect a catalyst 2950 to an existing 2924. Everything works ie: get link, recognize each other, authenticate, etc. However, the problem is that I cannot get to the Internet. I am using dot1q on the trunks. Any suggestions? thanks!
Hall of Fame Super Bronze
Re: Compatibility Issue between catalyst 2950 and 2924's
What's the device providing the internet connection (the switches mentioned above are strictly layer2) ?
Are you able to ping the local interface for the internet gateway ?
Did the connection to the internet work before ? If so, what changed ?
What versions are you running on?
As I recall, only Enterprise 2924s do Dot1Q trunking, standard are ISL only (which is not supported on the 2950).
The switches mentioned are connected to a catalyst 6509.
Yes, we are able to ping the local interface for the internet gateway.
We have not tried this before - regarding whether the connection to the internet worked before. thanks
169
