Community Member
complex port violation problem
we are having port security in our huge  network . when a PC is moved from one location to another port violation is found in switch logs and the pc is denied access to the network . in this cases we would   clear the port violation configuration and then re configure the port violation to make the port adapt to the new mac . but we experience a strange port violation even when we reconfigure the port security violation . reson being said by my seniors is that the mac is also learning in another switch . how to clear this issue and make the pc connect to the network without removing the port security in the switch interface .
1 ACCEPTED SOLUTION
Re: complex port violation problem
Have you tried "clear port-security dynamic address" command?
NT
Have you tried using "clear port-security dynamic address "
command? That will clear the MAC from the secure MAC list.
Hope this helps.
NT
Hall of Fame Super Gold
The issue and solution contradicts itself.
Your solution.
Your issue.
So why bother putting a sticky MAC address if users are allowed to move their PCs from one switch(port) to another?   Observe the two-skunk-rule.
A man walks into a general store in Vermont and mentions to the owner that he has a problem. A skunk has found its way into his house. He needs to get rid of it but is afraid of being sprayed.
"No problem!" exclaims the proprietor. "Skunks love carrots. Just buy a bunch of carrots. Cut them into pieces and make a trail out of the house into the woods. Use a plank to make a ramp down the front steps."
A week later the man returns to the store. "You sure were right about skunks liking carrots", he said to the owner. "So, you got rid of him?", the owner replied.
"No", said the man. "Now I have two skunks!"
Community Member
hi the solution leolaohoo provided doesnt solve our problem since we require port security in our switches . we just want to clear the cache of the mac table in the previous switch in which the pc  was there  . we removed the pc still the mac table is having it . it would be better if  there is a command to refresh the mac table of the switch.
NT
290
