Config Consolidation (sup2/msfc2 hardware platform config into 3750)
Currently 1misc-sp01/rp01 and 1misc-sp02/rp02 are running on sup2/msfc2 hardware platforms which is end of life.
Since they don't do anything special, I'm replacing them with a smaller router; a 3750.
I need help consolidating the config from the hybrid box (router + switch) to a 3750.
I have current configs attached.
1 REPLY
Re: Config Consolidation (sup2/msfc2 hardware platform config in
Here is my suggestion:
1. Use the following tool to convert catos config to IOS config.
2. Then it will be more easy for you to merge the config from sup02 to 3750.
https://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a0080816fbc.shtml
122
