Configration in 4500 catalyst switch
I have a catalyst 4507R switch. I would like to add two modules (24 port WS-X4424-GB-RJ45 and WS-X4418) in the existing 4507R switch. Do these modules are plug and play or I have to do some configurations in the supervisor? If any configuration needed then what is that?
1 REPLY
Re: Configration in 4500 catalyst switch
Hi Manoj,
Yes all line cards are plug and play and if your IOS release running on your supervisor supports these cards, they will automatically get detected and will move to OK state.
After that it is only the port configuration which you have to do on the line cards interfaces.
Ankur
*Pls rate all helpfull post
109
