11-11-2010 07:39 AM - edited 03-06-2019 02:00 PM
I have been working with :
WS-C6509 Software, Version NmpSW: 8.5(2)
Copyright (c) 1995-2005 by Cisco Systems
NMP S/W compiled on Dec 6 2005, 20:22:19
System Bootstrap Version: 5.3(1)
System Boot Image File is 'bootflash:cat6000-supk9.8-4-5.bin'
System Configuration register is 0x2
Hardware Version: 3.0 Model: WS-C6509 Serial #: SCA061300MT
PS1 Module: WS-CAC-1300W Serial #: SNI06090733
PS2 Module: WS-CAC-1300W Serial #: SNI06090730
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP1A-2GE SAD04420MHC Hw : 7.0
Fw : 5.3(1)
Fw1: 5.4(2)
Sw : 8.5(2)
Sw1: 8.5(2)
WS-F6020A SAD04480CPU Hw : 2.0
Sw :
4 48 WS-X6348-RJ-45 SAL0651A6ER Hw : 6.2
Fw : 5.4(2)
Sw : 8.5(2)
WS-F6K-VPWR Hw : 2.0
Sw : 1.1(1)
6 48 WS-X6148-GE-TX SAL09475SZ5 Hw : 1.1
Fw : 7.2(1)
Sw : 8.5(2)
7 48 WS-X6148-GE-TX SAL09475SZW Hw : 1.1
Fw : 7.2(1)
Sw : 8.5(2)
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 130944K 72741K 58203K 15616K 13433K 2183K 512K 115K 397K
Uptime is 7 days, 17 hours, 46 minutes
6509wc2> (enable)
I had an electrical maintenance when cisco were abruptly shutdown.
When it recovers configuration was different. Many port had status disable 1.
Does anybody know what happened ?
Thanks in advance,
Rosa
11-23-2010 02:06 PM
Rosa,
Were you able to re-enable the ports? Did they come back up successfully? Can you attach a "show log" to see if there is any crashinfo.
--Jeff
11-24-2010 05:44 AM
Thanks for your answer.
In fact, this problem rises because CATOS do not write changes in memory by default when using "System configuration mode set to text."
Rosa
11-23-2010 02:56 PM
I have seen this happen before on catos boxes , mostly the old 4006 boxes and consider it either a bug or design flaw. Not much you can do about it other than make sure you keep backup configs up to date and or put it on a UPS . Seeing catos is basically EOL it's not something they will fix . We used to see it happen once in great while when you got a quick power hit where the power goes out and almost immediately comes back on , for some reason that affects the nvram and some or all of the config gets wiped out.
11-24-2010 05:45 AM
Rosa
11-24-2010 07:42 AM
I'm not positive, but quite certain, since its been a while since I've run CATOS, ( and I do prefer it) but you have to do a wr mem when using text mode on CATOS. I've been digging for old docs, the original sups I used to run CAT on I'd swap back and forth for troubleshooting purposes...
11-24-2010 08:46 AM
Eric
You can do a wr mem but you can also setup an automatic save within a predefined time period if you want.
Only binary mode does an automatic save straigt away.
Jon
11-24-2010 09:55 AM
Thanks.
That was the problem.
Rosa
