01-14-2015 04:02 AM - edited 03-07-2019 10:13 PM
We have a number of WS-C3560-8PC-S switches and looking into upgrading all our switches to WS-C3560CG-8PC-S.
All ports are configured for various different v-lans.
To do the upgrade to Gb switches will I be able to just copy the configuration file from the old 10/100 switches and load it into the new Gb switches or will I need to manually configure each new Gb switch?
Thank you in advance for any assistance,
Craig
01-14-2015 06:21 AM
Hello Craig,
the interface names are changing. So you have to change "interface fastethernet" to "interface gigabitethernet" and the uplink ports must be renumbered.
Torsten
01-14-2015 06:37 AM
Thanks Torsten, so this is going to be quite a process :(
01-15-2015 11:08 AM
what i do is copy and paste the config into notepad. Then choose "find" then "replace" you can do the same for the numbering too.
01-20-2015 02:10 AM
In the world of networking, note pad or better Edit Pad is your best friend when it comes to configuration prep!
01-14-2015 10:10 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If you're also jumping IOS versions between the two models, you sometimes (rarely) can bump into a syntax change.
01-14-2015 10:55 AM
As Torsen mentioned its should be configured from fastethernet to Gigaethernet.
