Community Member
Configure 871W wifi devices to talk to wired devies
Guys,
here is my config. My wireless laptops get in fine, but when I plug a pc/laptop to the ports, I do not get an IP.
I even manually gave my pc an IP on the same LAN subnet but no communication.
Can you please help me on what's going on and how do I setup those ports to be on the same subnet as 10.6.2.0 so any device I plug into the ports can talk to the wireless devices and can also go out to the internet?
871W#sh run
Building configuration...
dot11 syslog
dot11 ssid caipwifi
authentication open
guest-mode
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.6.2.1 10.6.2.49
ip dhcp excluded-address 10.6.2.100 10.6.2.255
ip dhcp pool sdm-pool1
import all
network 10.6.2.0 255.255.255.0
default-router 10.6.2.1
no ip domain lookup
ip domain name yourdomain.com
username itadmin privilege 15 secret 5 $1$i9qi$BdCiOlAo4QPP4upVMPbQQ/
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key xxx address 66.66.66.66
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map mymap 10 ipsec-isakmp
set peer 66.66.66.66
set transform-set myset
match address insc_acl
archive
log config
hidekeys
bridge irb
interface Loopback0
ip address 1.1.1.1 255.255.255.252
interface FastEthernet0
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map mymap
interface Dot11Radio0
no ip address
encryption key 1 size 40bit 0 901CA78731 transmit-key
encryption mode wep mandatory
ssid caipwifi
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 10.6.2.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip policy route-map VPN-MAP
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
no ip http secure-server
ip nat inside source static tcp 10.6.2.2 6502 interface FastEthernet4 6502
ip nat inside source static tcp 10.6.2.2 3389 interface FastEthernet4 3389
ip nat inside source route-map ISP1 interface FastEthernet4 overload
ip access-list extended insc_acl
permit ip 10.6.2.0 0.0.0.255 10.21.30.0 0.0.0.255
permit ip 10.6.2.0 0.0.0.255 10.8.251.0 0.0.0.255
access-list 114 permit ip 10.6.2.0 0.0.0.255 10.21.30.0 0.0.0.255
access-list 180 deny ip 10.6.2.0 0.0.0.255 10.21.30.0 0.0.0.255
access-list 180 deny ip 10.6.2.0 0.0.0.255 10.8.251.0 0.0.0.255
access-list 180 permit ip 10.6.2.0 0.0.0.255 any
no cdp run
route-map VPN-MAP permit 10
match ip address 114
set ip next-hop 1.1.1.2
route-map ISP1 permit 10
match ip address 180
match interface FastEthernet4
control-plane
bridge 1 protocol ieee
bridge 1 route ip
871W#
1 ACCEPTED SOLUTION
Re: Configure 871W wifi devices to talk to wired devies
You need to add VLAN1 to the bridge-group as well so traffic between dot11 and FastE interfaces will be bridged. By default, your wired interfaces belong to VLAN 1:
int vlan 1
bridge-group 1
Laurent.
int vlan 1
bridge-group 1
Laurent.
Community Member
Laurent, thank you very much for the info.
As soon as I put those commands you suggested, my wired guys have now a presence on the network.
you're the best man!
thank you
any good links to read about this? I did some searching but found nothing.
Hall of Fame Super Silver
Hello Angel,
here it is a link to the chapter in configuration guide for wireless
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html#wp999879
Hope to help
Giuseppe
Community Member
Great stuff Giuseppe. Really good link with the basics.
436
