Configure HSRP multi-Vlan with NAT
Kindly
Everyone's tags (3)
Hsrp one vlan plus stateful nat works but unable to use in multi vlan environment.
Please help.
VIP Super Bronze
What type of device are you using?
Can you post "sh run" from your device?
Hi, here is my topology, and attached are the configs for R1 and R2..
=======   R1   =======
version 12.4
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$n2ON$l.VCLnNtg0vGLyKncWCPk/
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username wendell secret 5 $1$V03R$TRU0vGoOkqdwHwIH.vk.k0
archive
log config
  hidekeys
track 10 interface Serial0/1 line-protocol
track 20 interface Serial0/1 line-protocol
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
no ip address
speed 100
full-duplex
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.2 255.255.255.0
ip nat inside
ip virtual-reassembly
standby 10 ip 192.168.10.1
standby 10 priority 150
standby 10 preempt
standby 10 name GROUP10
standby 10 track 10 decrement 60
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.20.2 255.255.255.0
ip nat inside
standby 20 ip 192.168.20.1
standby 20 preempt
standby 20 name GROUP20
interface Serial0/1
ip address 2.2.2.2 255.255.255.0
ip nat outside
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 2.2.2.1
no ip http server
no ip http secure-server
ip nat Stateful id 10
  redundancy GROUP10
   mapping-id 10
   protocol   udp
ip nat pool NAT_POOL 2.2.2.2 2.2.2.2 prefix-length 24
ip nat inside source list NAT_ADDRESS pool NAT_POOL mapping-id 10
ip access-list extended NAT_ADDRESS
permit ip 192.168.10.0 0.0.0.255 any log
permit ip 192.168.20.0 0.0.0.255 any log
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login local
end
=======   R2   =======
version 12.4
hostname R2
boot-start-marker
boot-end-marker
enable secret 5 $1$hy/7$TzdG88xM6Nvgv8bYTv3q1/
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
username wendell secret 5 $1$sFCW$ze43rU6FkadiLG6X1JcYv.
archive
log config
  hidekeys
track 10 interface Serial0/0 line-protocol
track 20 interface Serial0/0 line-protocol
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 3.3.3.3 255.255.255.0
ip nat outside
clock rate 2000000
no ip address
speed 100
full-duplex
ip address 192.168.10.3 255.255.255.0
ip nat inside
standby 10 preempt
ip address 192.168.20.3 255.255.255.0
ip nat inside
standby 20 priority 150
standby 20 preempt
standby 20 track 20 decrement 60
interface Serial0/1
no ip address
shutdown
clock rate 2000000
ip route 0.0.0.0 0.0.0.0 3.3.3.1
no ip http server
  redundancy GROUP10
   mapping-id 10
   protocol   udp
ip nat pool NAT_POOL 3.3.3.3 3.3.3.3 prefix-length 24
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login local
end
R1 is default router for VLAN10
R2 is default router for VLAN20
R1 NAT for VLAN10
R2 NAT for VLAN20
When R2 is down, NAT for VLAN20 is not working, getting unreacheable from PC2
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
U.U.U
Wendell
452
