Webcast-Catalyst9k
configuring 2 IP addresses on a single port of Cat3750
hi,
I would like to know if is possible to configure 2 IP addresses on a single port of Cat3750.
I think that using the interface vlan xxx after I can use the ip address xxxx secondary command like on routers.
What do you say?
Thank you.
Regards.
Giuseppe
2 ACCEPTED SOLUTIONS
Re: configuring 2 IP addresses on a single port of Cat3750
You mean on a SVI?
Yes you can do that!
vlad
Purple
Yes you can do that on a SVI or a routed port , no different than a router .
You mean on a SVI?
vlad
Purple
212
