Configuring 6509 Uplink port for UCS FIC 6120
I'm having issues trying to configure a basic uplink interface connection to my Cisco FIC 6120. I am not configuring the port-channel yet, but just an individual port for each FIC. The following are my configs.
interface GigabitEthernet7/39
switchport
switchport mode trunk
no ip address
spanning-tree portfast trunk
GigabitEthernet7/39 is down, line protocol is down (notconnect)
Hardware is C6k 1000Mb 802.3, address is d0d0.fcd.5b32 (bia
d0d0.fcbf.5b32)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is desired
Clock mode is auto
Last input never, output never, output hang never
Last clearing of "show interface" counters 1y6w
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
I have configured a few other UCS's before this one, and I can not begin to
figure out the issue. I made sure that the SFP being used in the FIC is for
a LAN at 1 Gb speed, which matches what I have in the 6509. I also made
sure to specify the speed on the UCS at 1GB. But I did notice that the only setting for speed on the configured port on the 6509 is "speed nonegotiate".
416
