Webcast-Catalyst9k
Configuring a 3750G Switch for MS Network Load Balancing
I need to configure a cisco 3750G switch to handle Microsofts Network Load Balancing.
Can anyone help, is there anything special that I need to do ?
1 REPLY
Re: Configuring a 3750G Switch for MS Network Load Balancing
I had some issues when using Mutlicast for WLBS - switching to Unicast as WLBS protcoll solved the problem. I didn't had to prepare any special configuration on the switches the servers are connected to.
As far as I remember an articel from Microsoft Knowledge Base servers running WLBS shoulf not be connected to switches which are running layer-3 switching.
276
