Configuring a trunk with an access command too?
Hi, I am just curious to know, what does this do?
interface GigabitEthernet2/1
switchport access vlan 800
switchport trunk native vlan 50
switchport trunk allowed vlan 50,60,800
switchport mode trunk
The switchport is obviously a trunk (as per the last command), but then why is there also an access command to VLAN 800?
What I don't understand is that a trunk's purpose is to trunk multiple VLANs across a switchport so why does the above configuration specify access to a single VLAN?
Re: Configuring a trunk with an access command too?
That's a misconfiguration. You can safely remove 'switchport access vlan 800' command from the interface config as it isn't doing anything. Is it possible that might be legacy config that someone forgot to remove after the port was configured as a trunk.
Sundar
Thank you for the reply, however, I read this at another forum:
"It sets the port VLAN for when the port is in access mode. If you set
the mode to access (switchport mode access) then the port VLAN would
switch to 800 from 50; if you switch to one of the sensing modes
(switchport mode dynamic ...) then the state the port negotiates into
will determine the port VLAN."
I have also heard that the "vlan access port" command acts as a trunk :S I hope someone can give me a firm answer as I have been given three different explanations so far.
Thank you for your time.
161
