Configuring - Cisco 2921 with Switch Module/POE PS and 3750-x 24 port switch
This is what I have
- Cisco 2921 router
         with SM-ES2-24-P switch module and
                 POE power supply
-Cisco 3750x- 24 port Switch
I have port G1/0 (which connects to 24p Switch Module port g0/26 logically) configured with 3 sub interfaces (management, User and VOIP)
I want to connect 3750x to G0/1 on 2921 via fiber GBIC but want to use same three VLANs
I can not daisy chain 3750x via the switch module because it does not have fiber port.
I do not want to create another routed (g0/1) interface because I want to keep Users on both switches on the same subnet without further splitting the subnet in two.
I hope I am not making this confusing.
How can I bridge g1/0 and g0/1 so I can pass vlan traffic between two switches?
Second problem i have is ...
I have a VOIP connected to switch module (SM) and it is not getting any power.
I went in to all the interfaces on SM and issued power inline auto command
On the SM (sh power inline) - available is 0.0(w)
on the 2921 (sh power inline)
   - power supply status is good,
   - maximun power available is 280.
   - interface G1/0( which connects to SM)
      *device is unknown
      * powered off
     * allocated 0.0 watts.
I already tried resetting SM
Is there any other command I need to issue?
thanks for your help.
  • LAN Switching and Routing
Everyone's tags (7)
1 REPLY
I'm having a similar issue. I
I'm having a similar issue. I can get trunked connectivity between the switch module and the router if I put the IP address on the router sub interface, but not if I put it on a VLAN interface. I was hoping to have it on a VLAN sub interface on the router so I could use Gig0/1 and Gig0/2 to connect other switches and have them on the same VLANs. I'm using Gig1/0 on the router side and Gig0/51 on the switch side (48-port module).
Any help? Am I on the wrong track altogether?
964
