Configuring COS on 2960G switches with non-cisco phones
I have 7 POE switches that have ESI IP phones attached.  I have two VLANS, 1 and 2.  VLAN 2 is used for voice and is defined in each switch.
The ESI IP phones connect to my POE switch ports and the pc attaches through the ESI IP phone.
I have had voice quality issue between floors in my building.  Talking to others on my floor via the IP phone, there are no voice quality issues.
On each switch i have the following global commands:
no mls qos rewrite ip dscp
mls qos
Below are my port configurations.
interface Port-channel1
switchport trunk allowed vlan 1,2          This is my EtherChannel
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet0/1                    This is an example of a port that my ESI IP phones are attached to.
priority-queue out
mls qos trust cos
channel-group 1 mode on
interface GigabitEthernet0/24
switchport trunk allowed vlan 1,2          This is an example of my uplink port to other switches.
priority-queue out
mls qos trust cos
channel-group 6 mode on
POESWITCH#sh mls qos int gi1/0/15
GigabitEthernet1/0/15
trust state: trust cos
trust mode: trust cos
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Mapsh msl
Trust device: none
qos mode: port-based
GVS12SW02GBPOE#sh int gi1/0/15 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 1,2
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Is this a correct configuration to prioritize voice traffic?
1 REPLY
Here are statistics from an active phone.
POE#sh mls qos int gi1/0/13 statistics
GigabitEthernet1/0/13 (All statistics are in packets)
  dscp: incoming
  0 -  4 :     2953143            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0       668724            0            0
45 - 49 :           0      2364721            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :      406289            1            8            0         1013
  5 -  9 :           0           21         6565         5521            4
10 - 14 :           5            0            8            0            0
15 - 19 :           0            7            0           12            0
20 - 24 :           6            1           10            0          149
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           1            0      1786175            0           19
45 - 49 :           0      2377678            0      3530882            0
50 - 54 :           9            0            0            0            0
55 - 59 :           0        95542            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :    20326768            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :   223618994          978         9616         2003         3177
  5 -  7 :         733         3266     10105807
  output queues enqueued:
queue:    threshold1   threshold2   threshold3
queue 0:           0           0           0
queue 1:   190675369      113177    10109078
queue 2:           0           0           0
queue 3:           0           0    33573181
  output queues dropped:
queue 0:           0           0           0
queue 1:          32           0           0
queue 2:           0           0           0
queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
391
