Configuring DHCP and VRRP
Im trying to set up a VRRP and DHCP
But I can't get the DHCP to work : (
I  have attached the diagram and this is my config .  In another config try I have assigned Ips to the interfaces facing the SW ( 1.1.1.1 and 2.2.2.2)
but still nothing.
- In another note I have divied the pool as suggested in another blog to evoid ip overlaping.
When I run DHCP comand on the PCs, I get a message indicating DHCP server was not found.
Thanks  in advance
- Noe
CUERNAVACA  :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
config t
hostname CUERNAVACA
int Gi0/0
desc connected to PUEBLO
ip address 10.1.23.3 255.255.255.0
standby 1 ip 10.1.23.1
standby 1 priority 110
no shut
ip dhcp pool CS_PUEBLO
network 10.1.23.0 255.255.255.128
default-router 10.1.23.1
domain-name CUER.com
lease 7
exit
ip dhcp excluded-address 10.1.23.1 10.1.23.10
interface FastEthernet1/0
description connected to SW LAN
no ip address
ip helper-address 10.1.23.1
duplex full
speed 100
end
PUEBLA  :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
config t
hostname PUEBLA
int G0/0
desc connected to CUERNANVACA
ip address 10.1.23.4 255.255.255.0
standby 1 priority 105
no shut
network 10.1.23.129 255.255.255.128
lease 7
exit
no ip address
duplex full
speed 100
end
  • LAN Switching and Routing
Everyone's tags (4)
1 REPLY
The 'ip helper-address'
The 'ip helper-address' command is used if you have a 3rd party dhcp server like Windows.  In this case, you don't need the ip helper-address command.
The second thing is that the interface ip subnet should match the DHCP pool's subnet.  You have a /24 for the interface but /25 for the pool.
982
