Configuring Dos Attack Protection on Catalyst6500
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080435872.html
I saw on this configuration guide some DOS protection examples.
Examples of some rate-limiters on Catalyst6506:
mls rate-limit multicast ipv4 fib-miss 10000 10
mls rate-limit multicast ipv4 non-rpf 100 100
mls rate-limit unicast cef glean 20000 60
mls rate-limit unicast ip rpf-failure 100000 100
mls rate-limit unicast ip icmp unreachable no-route 100000 100
mls rate-limit unicast ip icmp unreachable acl-drop 100000 100
mls rate-limit unicast ip errors 100000 100
mls rate-limit all ttl-failure 70000 150
Question:
1.Are these examples recommended and tested to protect your network from DoS attack
whatever network design, network utilization you have? Or they are just examples?
2. If they are just examples, how can i find out or calculate rate-limiters for security for my real network? So that it cannot affect the important traffic
thanks
Silver
Re: Configuring Dos Attack Protection on Catalyst6500
I haven't used the above mls commands. You can look into a feature called Storm-control which can limit unicast, broadcast and multicast on the interface. Below you can a link for storm-control feature:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a9f.html
Let me know if this helps,
Appreciate your rating,
You said you hadn't use this features. Why?
Are these features useless? or something else?
thanks
Silver
Hello Leo,
I didn't say this configuration is useless. I usually try to use the storm control feature which can limit some types of DoS attacks.
The above are some DoS protections based on QoS. On thing to note that there is no standard configuration for QoS. What I mean is because different networks have different type of traffic it is very hard to say this typical configuration would work on all networks. This is because some networks maybe using multicast a lot and some other are not for example.
Therefore, after you apply the above commands you may still need to modify the limiting rates to be adequate with your network traffic type.
Hope this clarifies the issue,
165
