configuring fast ethernet port
hi I am confused in configuring fast ethernet in the 2600 series router ,can you give exact command path for configuring ?
  • LAN Switching and Routing
Re: configuring fast ethernet port
Hi Ajay,
I am not sure what do you want to configure but if it is just a basic configuration then
Router#
Router#config t
Router(config)#
Router(config)#interface fa0
Router(config-if)#ip address x.x.x.x x.x.x.x
Router(config-if)#no shut
Router(config-if)#exit
Router(config)#exit
Router#wr mem
Please update if you want to configure something specific?
Ankur
Please see the link below for configuring the interfaces on 2600 router.
http://www.cisco.com/en/US/partner/products/hw/routers/ps259/products_configuration_guide_chapter09186a008007e602.html#wp1021245
HTH,Please rate if it does.
-amit singh
354
