Community Member
Configuring HSRP on a CISCO 2800 router
Good Day,
Could you please guide me how to configure HSRP between two CISCO 2800 series routers? How many switches are required for the effective implementaion of HSRP? Is there any neccesity to do HSRP configurations on the ISP side router? Please do guide me with your professional advice.
Thanking you in anticipation,
Sam
1 ACCEPTED SOLUTION
Re: Configuring HSRP on a CISCO 2800 router
Sam,
You need only a single switch to connect to routers with the LAN ports on this switch. HSRP is used for Gateway redundancy for your LAN hosts. It is not implemented on the WAN/ISP side.
Please see the link below for HSRP configuration:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fbb3.html
HTH,please rate if it does.
-amit singh
Sam,
-amit singh
Community Member
Good Day Sir,
Your response was very helpful.
Once again I thank you for the effort done.
Best Regards,
Sam Varghese
1748
