Configuring "system mtu jumbo" during production?
Martin Erman
Hello.
Will changing
system mtu jumbo
from 9000 to 1500 disrupt the network if done during production?
Martin
ajay chauhan
Level 7
Level 7
Martin-Reset the switch afterwards for the MTU change to take effect.
Ajay
5 Replies 5
mohseen patel
Hi Martin,
What device you are planning to make this change ?
Br.
Mohseen
It is on a:
WS-C3750E-24TD
Hi Martin,
You already have answer but just FYI on 3750 jumbo frame is only supported on Gigabit Ethernet ports.
Br.
Mohseen
ajay chauhan
Level 7
Level 7
Ajay
Ok, thank you.  Will have to do it during planned downtime then.
/M
