configuring rapid spanning tree
folks
i have 2 * 3560es set up for resilience with 2 uplink ports but spanning tree takes 50 secs to failover so i want to enable rapid spanning tree
can anyone let me know the relevant commands or post a link for a config guide
i'm running c3560e-universalk9-mz.122-35.SE5
thanks to anyone taking the time to reply
3 ACCEPTED SOLUTIONS
Hall of Fame Super Blue
Re: configuring rapid spanning tree
Michael
Have a look at this document, it is for the 6500 but it is relevant to the 3560 -
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00807b0670.shtml
come back if you have further questions.
Jon
Hi Michael,
To enable Rapid STP, all you have to do is use the spanning-tree mode rapid-pvst in global configuration mode.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_35_se/configuration/guide/swstp.html#wp1156866
Make sure you put this command on all your switches, otherwise the switch without this command will use 802.1D.
HTH,
jerry
Purple
Michael
Jon
jon
once again, thanks for your input
greatly appreciated
Hi Michael,
HTH,
jerry
jeye
many thanks for your help
greatly appreciated
Purple
glen
appreciated
408
