neo
Configuring SNMP notification for Statefull Switchover on CatOS 6500
Does anyone know the equivalent command syntax to enable "ciscoRFSwactNotif trap" on a 6500 switch running CatOS. I need to be able to detect modules transitioning from active state to standby and vice versa. I have been able to enable traps for devices running IOS, the problem lies in doing the same for devices running CatOS.
Any one with a clue or a link with information that can help enable this feature?
1 ACCEPTED SOLUTION
Silver
Re: Configuring SNMP notification for Statefull Switchover on Ca
Hey,
'set snmp trap redundancy' should enable traps for CISCO-RF-MIB, including ciscoRFSwactNotif. This notification only seems to be supported in CatOS 8.x and later, more details here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/command/reference/setsn_su.html#wp1287367
ftp://incoming.cisco.com/pub/mibs/supportlists/wsc6506/wsc6506-supportlist-catos.txt
/Phil
Silver
Hey,
/Phil
neo
Thanks for your prompt response, you are indeed a life saver. it works perfectly.
neo@cisco
262
