configuring to not accept redirects
Is there a command similar to "no ip redirects" but in reverse? I think my router is being affected by another router sending redirects to it. I would like to configure my router to ignore these redirects.
Diego
1 ACCEPTED SOLUTION
Gold
Re: configuring to not accept redirects
If you keyed in the sample exactly then you forgot about the implied deny any any at the end. You need to put in a permit ip any any as the last line of the access list.
you can block all redirects through an ACL:
access-list 100 deny icmp any host 10.1.1.1 redirect
interface FastEthernet0/0
ip address 10.1.1.1 255.255.255.0
ip access-group 100 in
Hope this helps! Please rate all posts.
Regards, Martin
Wow, that was interesting. I created and applied the ACL and it prevented all clients on the interface it was applied to from talking to anything accross the router. The weird part is that there were no hits, zero, zilch on the ACL!
How can that happen?
Diego
Gold
Uh... I'm an idiot.
Thanks, that was it.
Diego
481
