configuring trunk betwen IOS (12.2) and CATOS (8.5(2))
Rosa Ladeira
switch 1: WS-C2960S-24PS-L / c2960s-universalk9-mz.122-55.SE7 / port g 1/0/28
switch 2: WS-C6509 + WS-X6K-SUP1A-2GE / cat6000-supk9.8-4-5.bin / sc0
configuring trunk on fiber interfaces
switch 1#sh interfaces g 1/0/28 trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/28    on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/28    1-4094
Port        Vlans allowed and active in management domain
Gi1/0/28    1-7,10-11,14,20-21,23,105-107,110,112,114,130-131,160,168,177,232,254,931
Port        Vlans in spanning tree forwarding state and not pruned
switch 1#
on switch 2 the possibilities are:
switch 2> (enable) set trunk 5/1 [on | off | auto | desirable | nonegotiate] [dot1q | isl | negotiate]
What should I choose?
Thanks Rosa
2 Accepted Solutions
Parvesh Paliwal
Level 3
Level 3
I ll choose for 'on' and dot1q.
Expecting resolution with this.
If helpful, please mark the answer helpful and rate.
5 Replies 5
Reza Sharifi
 To match encapsulation type on both switches try "set trunk 5/1 dot1q" on the second switch.
Hi!
I have executed on switch 2:
swtich 2 >  (enable)  set trunk 5/1 on 1,2,3,4,5,6,7,10,11,14,20,21,
23,105,106,107,110,112,114,130,131,160,168,177,232,254,931 dot1q
I have gotten:
swtich 2 >  (enable) sh vtp domain
Version      : running VTP2 (VTP3 capable)
Domain Name  : impa                             Password  : not configured
Notifications: disabled                         Updater ID: X.Y.Z.W
Feature        Mode           Revision
VLAN           Client         18
Pruning             : disabled
VLANs prune eligible: 2-1000
swtich 2 > (enable) sh trunk 5/1 detail
* - indicates vtp domain mismatch
# - indicates dot1q-all-tagged enabled on the port
$ - indicates non-default dot1q-ethertype value
 5/1      on           dot1q          not-trunking  1
Port      Peer-Port  Mode         Encapsulation  Status
 5/1      unknown    unknown      unknown        unknown
Port      TrunkFramesTx         TrunkFramesRx         WrongEncap
 5/1                         0                     0           0
 5/1      1-4094
 5/1      1
 5/1
swtich 2 > (enable)
I still have on switch 1
switch 1# sh int g 1/0/28 trunk
Gi1/0/28    1-4094
switch 1# sh vtp status
VTP Version capable             : 1 to 3
VTP version running             : 2
VTP Domain Name                 : impa
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Disabled
Device ID                       : c414.3c74.c800
Configuration last modified by 147.65.2.7 at 11-5-13 09:20:23
Feature VLAN:
VTP Operating Mode                : Client
Maximum VLANs supported locally   : 255
Number of existing VLANs          : 31
Configuration Revision            : 18
MD5 digest                        : 0xAE 0x64 0x23 0x5C 0x60 0x42 0x20 0xA1
                                    0xC3 0xF5 0x26 0x9C 0x5F 0x28 0x1A 0x70
Correct Answer!
It works fine.
Thanks a lot.
Rosa
Parvesh Paliwal
Level 3
Level 3
