Webcast-Catalyst9k
configuring username on routers
Hi all, to configure a username on routers, do I just type
config
username xxxx password xxxx
or do I need to do aaa new model first ?
1 REPLY
Re: configuring username on routers
Hi Carl,
To configure a local user, you just need to type...
You don't need "aaa new model" if you are not using a remote authentication host (i.e. RADIUS/TACACS) or configuring "Login Password Retry Lock-out (IOS 12.3(14)T)".
To obscure all text passwords using a Vigenere Cipher. Type...
service password-encryption
..but this can still be decrypted.
If you want a password with MD5 hashing (IOS 12.2(8)T), use the command...
username secret
Dandy
120
