Webcast-Catalyst9k
Configuring WPA and WEP on Cisco router
I would like to set up my Cisco 877w router with two SSIDs, WPA (currently working in my config) and WEP.
I have dumped my current config at the end of this question which is fully working for WPA.
My aim is to have:
  • Another SSID (AIBONET) with WEP authentication
  • The two networks having exactly the same access
I have consulted the documentation including Chapter 9 (Configuring a Wireless LAN Connection) of the Cisco Configuration Guide for detailed instructions on how to configure the router but can't seem to get it working for my configuration.
Any advice would be appreciated,
My current configuration is as follows:
Current configuration : 3995 bytes
version 12.4
no service pad
hostname CISCO877
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 xyz.
aaa new-model
aaa session-id common
crypto pki trustpoint TP-self-signed-240059495
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-240059495
revocation-check none
rsakeypair TP-self-signed-240059495
dot11 syslog
dot11 ssid CISCO877
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 1234567890
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.2.1.0 10.2.1.10
ip dhcp excluded-address 10.2.1.200 10.2.1.254
ip dhcp pool lanpool
network 10.2.1.0 255.255.255.0
dns-server xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
default-router 10.2.1.1
lease 0 2
no ip domain lookup
ip domain name my.domain.com
ip name-server xxx.xxx.xxx.xxx
username nick privilege 15 secret 5 xyz
archive
log config
hidekeys
ip ssh version 2
bridge irb
interface ATM0
mac-address 1111.2222.3333
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode adsl2+
interface ATM0.1 point-to-point
description BE Broadband
ip address xxx.xxx.xxx.xxx 255.255.252.0
ip nat outside
ip virtual-reassembly
atm route-bridged ip
pvc 0/101
oam-pvc manage
encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
description WIRELESS INTERFACE
no ip address
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid CISCO877
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description Local Network
ip address 10.2.1.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx
no ip http server
no ip http secure-server
ip nat inside source static tcp 10.2.1.1 22 interface ATM0 22
ip nat inside source list 111 interface ATM0.1 overload
ip nat inside source static tcp 10.2.1.81 9000 interface ATM0.1 9000
ip nat inside source static tcp 10.2.1.81 3389 interface ATM0.1 3389
ip nat inside source static tcp 10.2.1.81 8182 interface ATM0.1 8182
ip nat inside source static tcp 10.2.1.81 80 interface ATM0.1 80
ip nat inside source static tcp 10.2.1.81 443 interface ATM0.1 443
access-list 1 permit any
access-list 99 permit 10.2.1.0 0.0.0.255
access-list 99 remark SSH Allowed Hosts
access-list 110 remark MYVPN TO REMOTEVPN
access-list 110 permit ip 10.2.1.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 111 deny ip 10.2.1.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 111 permit ip 10.2.1.0 0.0.0.255 any
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner exec ^C
line con 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
access-class 99 in
privilege level 15
transport input ssh
transport output none
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Everyone's tags (4)
1393
