09-02-2009 03:09 PM - edited 03-06-2019 07:33 AM
Hi, just wanted to confirm:
If I need to let only two IP addresses (1.1.1.1 and 1.1.1.2) connect to server 192.168.206.5, I should bring line 40-70 to the top of the access-list below, correct?
ip access-list extended LETTWOPEOPLECONNECT
10 permit icmp any any
20 deny ip host 192.168.206.5 any
30 deny ip any host 192.168.206.5
40 permit ip any host 1.1.1.1
50 permit ip any host 1.1.1.2
60 permit ip host 1.1.1.1 any
70 permit ip host 1.1.1.2 any
80 permit ip any any
Solved! Go to Solution.
09-02-2009 03:19 PM
We don't know the direction of this ACL (in|out).
Knowing the direction will help saving some entries such as:
can be just one entry
or
But to answer your question, yes moving 40-70 before the deny 20-30 will let those hosts connect to server 192.168.206.5 but you can streamline the ACL with less ACEs.
__
Edison.
09-02-2009 03:18 PM
Marlon
Yes you would need to move the entries above line 20. Actually you could just write 2 more specific entries ie.
11 permit ip host 1.1.1.1 host 192.168.206.5
12 permit ip host 1.1.1.2 host 192.168.206.5
You could make them even more specific by using only the relevant ports (TCP/UDP) that 1.1.1.1/2 need to connect to on server 192.168.206.5
I'm assuming this acl is applied inbound on the relevant interface.
Jon
09-02-2009 03:19 PM
or
__
Edison.
09-02-2009 03:21 PM
Thanks!!! You guys rule.
