Confirming "erase" procedures on 4507
Hi, if I need to clear all configuration on my 4507 (but leave the existing IOS on flash OK, I am planning to get to console on each supervisor and do:
Switch#write erase
then reload it.
Is that all or anything special I need to do when dealing with the supervisor engine?
Purple
Re: Confirming "erase" procedures on 4507
That will wipe out any config minus anything that is in the vlan.dat file .
I did 'write erase' and I see that vlan information was wiped out. I just see a vlan 20 and obviously vlan 1.
Purple
Right if it had wiped out everything you would not see a vlan 20 . The main config is wiped out but the vlan info in the vlan.dat is there . I would just manually get rid of vlan 20 .
conf t
no vlan 20
Actually that may not be correct. It sounds vlan got wiped out by configuration on the first supervisor...
Thanks.
355
