Confusion : 4500R, 4500E and 4500R-E
I have some confusions with respect to the 4500R and the 4500E series
a) Can we put a Sup6E on the 4500R?
b) There is model "4505R-E". Is this "R-E" a new series like "R" and "E"?
c) Can i put a E series line card on a 4500R?
Thnaks in advance.
Sonu
Blue
Re: Confusion : 4500R, 4500E and 4500R-E
The 4500Rs have slots for redundant supervisors.
The 4500Es have 6Gpbs & 24Gpbs line card slot speeds.
The 4500R-Es have redundant supervisor slots and 6Gbps & 24Gbps line card speeds.
Standard 4500 (non R, E or RE) have 6Gbps line card speed and single supervisor support.
Please see the following link for 4500 model/capability comparisons:
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
Hall of Fame Super Blue
Sonu
a) Yes you can. The sup6 is compatible with both the new E chassis and the previous non-E chassis.
b) Can't find a link to that. Could you post link as i haven't come across a 4505 before.
c) No you can't. From the 4500 Q&A
Q. Are the E-Series line cards supported in non-E-Series chassis?
A. No. The classic Cisco Catalyst 4000 and 4500 chassis maximum per slot capacity is 6 gigabits per slot.
Jon
Hall of Fame Super Bronze
a)The Cisco Catalyst 4500 Supervisor Engine 6-E is compatible with classic Cisco Catalyst 4500 line cards, chassis, and power supplies,
b) Yes, R = Redundant capable (dual Sup)
E = New Series that support 24Gbps Module per slot
c) No.
HTH,
__
Edison.
1441
