connect 2 switch with fiber
Hi everybody,
I´m trying connect two catalyst 3560 Catalyst switch through fiber.  I have a network in the office, it is working. Now, I need to take a switch in my office network (switch A) and add a new switch (switch B) for connect a near office. I have the same converter modulo in   both extreme (finisar trj8519p1bnl-mc), I configured the switch B with Ethernet wire (from 10.0.0.1) and I put an IP within to office range IP (the same that others switch).
But when I connect the fiber in both switch port, the ports led are off. When I access to web interface from switch A, I can see the fiber port in yellow.
Somebody can help me?
Thanks!
1 ACCEPTED SOLUTION
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Unsure if this is your issue, but many Cisco devices, by default, won't run non-Cisco optics.  If not already doing so, you might try adding "service unsupported-transceiver" to your configuration.
Super Bronze
Disclaimer
Posting
And how can I do it?
Super Bronze
Disclaimer
Posting
config t
end
wr
Can you give me more
Can you give me more information?
thanks!
Super Bronze
Disclaimer
Posting
"... more infomation?"
Such as?
Do you know how to use the command line?
86
