Connect 3560 to Linksys DGS1224T via SFP
I have a 3560 that I want to connect to a Linksys GB switch.  I have the correct SFP for each switch, but the connection does not work.  Is there any way for this to work?
VIP Super Bronze
Re: Connect 3560 to Linksys DGS1224T via SFP
Just to clarify
The connection on both sides are Gig right?
Do you see a link light on either side?
Reza
yes, both are gig and both show link lights.
VIP Super Bronze
did you do a "no sh" under the interfaces?
yes
I just needed to add the same VLAN id to the linksys corresponding to the VLAN on the 3560.  So, all is well.  Thanks for the responses!
454
