Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Connect 3750 to 4507
Scenario:
A 4507 in data closet 1 is connected to a 6513 in data center.  This is a layer 3 connection.  I want to connected a 3750 in data closet 2 to the 4507 in closet 1.  This will be a layer 2 connection.  The mgmt ip of the 3750 will be from a vlan created on the 4507.  I do not get a link light.  I have traded out gbics and fiber patch cables.  Does anyone know what I am missing?
Green
Hi,You are trying to run a
You are trying to run a 10G interface at 1G
You already have a 10G interface in slot 3 as a 10G.
Try ading thi to your config
hw-module uplink select all
Read this reference
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/31sg/command/reference/cmdref/ch2a_ins.html#wp1505563
Hope this helps
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Thanks for your reply.  I don
Thanks for your reply.  I don't have the option of selecting 'all'.  I can only select 10G or 1G.  I want to only use one interface(3/6) for the uplink to a 1G switch.
73
