Connect a 10Gb X2 and a TwinGig X2 to same supervisor WS-X45-SUP6-E?
athemistocleous
We would like to connect a 10Gb X2 and a TwinGig X2 to the same Supervisor (WS-X45-SUP6-E) is this possible. The release note are a little vague.
thanks
Andreas
Reza Sharifi
Hi Andreas,
According to the datasheet you can do 10Gig or 1Gig (using the TwinGig) on either slot.  So yes, you should be able to do 1 10Gig and 2 1Gigs.
Here is more info:
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps9294/product_data_sheet0900aecd806df543.html
Reza
Hi Reza,
Thanks for the reply.
I also have that datasheet but there seems to be conflicting documents if you see below:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/52sg/configuration/guide/sw_int.html#wp1084402
This says there is a limitation.
So im having trouble to to clarify this and i dont have the equipment to test this.
thanks
Andreas
Hi Andreas,
After reading the link you posted, it seems that you can only do 10Gigs or 1Gigs and not a mix of both, but than again to be sure, it needs to be test it.
Reza
